some time ago I've built a power supply based on 3x LM317HVT IC's in parallel (circuit in the attachment) and now I'd like to add current limiting to it. I was looking for a circuit that would limit the output current to 3A (max 3.5A) but I couldn't find anything that would do that at any given voltage (1.25V - 52V). I'm using a transformer with 44V AC secondary. Can anyone help me with building such circuit?
Thanks in advance
Apart the other valid advices, I think nobody spotted the 1kΩ limited LED in the circuit...
That's about 35mA in worst case (no load and a bit of AC overvoltage)
(*) through a LED that I guess is just as an ON indicator.
Make that 10-22kΩ. Modern LEDs are bright and in any case (vintage or modern) would last much longer when fed with moderate current.
And if you want to get 5A out you'd better double the input capacitor. Make that 2 x 4700µF.
OK... now that I've read more carefully that is 3-3.5A... so make that 2x3300µF
(*) the circuit diagram specifies 24V, but in the text you write 44V (so it would be even worse)...
