Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Electronics
Beginners
4 pin PCB right angle fan header
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: 4 pin PCB right angle fan header (Read 4042 times)
jshonw
Contributor
on:
June 08, 2014, 09:47:40 pm »
I am looking for PCB right angle headers that can accept 4 pin PC fans. The key tab is 3 pins wide and is offset to one side, so that it can accept 3 pin fans also. Do they exist and where can I get them?
Logged
fluxcapacitor
Frequent Contributor
Country:
Re: 4 pin PCB right angle fan header
Reply #1 on:
June 09, 2014, 12:17:25 am »
do you want thru hole or surface mount. This might do if you notch out the plastic,this one is thru hole.
http://www.ebay.com/itm/10x-KF2510-4P-Connector-Kits-2-54mm-Pin-Header-Terminal-Housing-Right-Angle-/120992682503
Logged
jshonw
Contributor
Reply #2 on:
June 09, 2014, 12:52:32 am »
Trimming the tab as you suggested on a regular 4 pin might work for now, since I am only at the prototyping stage. Hopefully, I can find some proper ones, if this project ever goes into production.
Logged
peterszilagyi91
Newbie
Country:
Reply #3 on:
April 16, 2018, 06:06:31 am »
Have you find the right angle version for this connector?
Logged
palpurul
Regular Contributor
Country:
Hey
Reply #4 on:
April 16, 2018, 06:14:47 am »
I am sure you can find a suitable one from digikey.
https://www.digikey.com/products/en/connectors-interconnects/rectangular-connectors-headers-male-pins/314
Logged
Print
Search
Pages: [
1
Go Up
« previous
next »
Electronics
Beginners
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
