Author Topic: Help! how to improve the preformance of DS1054Z FFT mode?  (Read 5283 times)
Offline ali6x944Topic starter
  • Country: sa
« on: February 18, 2016, 08:14:07 am »
Hi everyone,
I was wondering about if i could improve the preformance of DS1054Z oscilloscope in FFT mode after i watched Dave's great video about the subject...
So now i wonder how to improve the preformance of DS1054Z FFT mode?
Offline Mechatrommer
  • Country: my
  • reassessing directives...
Re: Help! how to improve the preformance of DS1054Z FFT mode?
« Reply #1 on: February 18, 2016, 08:43:16 am »
Install latest firmware 4.3.2.3 sp2
  • Country: sa
« Reply #2 on: February 18, 2016, 09:17:25 am »
Thanks that realy helped :-+
  • Country: my
Offline robrenz
  • Real Machinist, Wannabe EE
« Reply #4 on: February 18, 2016, 02:35:12 pm »
Thanks Mechatrommer I just did the upgrade and it is quite an improvement.
Offline Wirehead
    • Wirehead.be
« Reply #5 on: February 19, 2016, 10:31:54 am »
Also take a look at http://rheslip.blogspot.be/2015/09/software-spectrum-analyzer-for-rigol.html
If you change the code a little, you can make it work via VISA over network as well.
"to remain static is to lose ground"
  • Country: sa
« Reply #6 on: March 04, 2016, 05:30:27 am »
will it work if the 100Mhz hack is installed?
Offline Wirehead
    • Wirehead.be
« Reply #7 on: March 04, 2016, 07:51:29 am »
sure why not?
Offline borjam
  • EA2EKH
« Reply #8 on: March 04, 2016, 09:19:08 am »
It would be great if the guys from Rigol had a look at a venerable, ancient Lecroy 9400 :) (*)
Even though the slow M68000 CPU can take more than 20 seconds to refresh the FFT if you go too far, you can select the number of points, real/imaginary/modulus, etc.
I guess that, once you have the FFT implemented, it doesn't add any cost in performance terms to give it some flexibility.
(*) I've got an old one and that one was my first exposure to digital oscilloscopes with math operation before purchasing a DS1074Z :)
Offline oaliey
« Reply #9 on: March 04, 2016, 11:55:19 am »
Umm, wow how did I miss this update. Can't believe that's from almost a year ago. It looks like it makes the fft function almost usable rather than the joke mine currently is. Does the firmware also allow the decode functions to work on the entire memory rather than just the displayed on screen trace?
  • Country: my
« Reply #10 on: March 20, 2016, 11:46:37 am »
for higher than 12Kpts that Rigol FW offered. i use this SW to extend the FFT capability...
http://www.soasystem.com/download/visadso/
20Mpts FFT, 50Hz resolution bandwidth (RBW) DC-500MHz:
but currently only 200Kpts is published, more memory FFT needs further testing...
200Kpts is already 10-20 folds than the offered by the built in FW...
  • Country: sa
« Reply #11 on: March 20, 2016, 06:25:13 pm »
man, of course it does, it is simply, awesome!
u should try it, but be careful! some websites would give u firmware that will damage your scope so be careful...
but still it is awesome! ;D
