Author Topic: Modifying a Class A amplifier design for more gain  (Read 1370 times)
Offline AlessandroAU
« on: February 27, 2015, 12:01:15 pm »
Hi all,
I've built this small circuit and am using it as a microphone preamplifier:
http://sound.westhost.com/p13_fig2.gif
source: http://sound.westhost.com/project13.htm
It has a maximum gain of about 30dB. Would be feasible to increase the gain to around 50dB by adjusting values with the existing circuit topology or would a different design be required?
Offline T3sl4co1l
    • Seven Transistor Labs
Re: Modifying a Class A amplifier design for more gain
« Reply #1 on: February 27, 2015, 12:49:38 pm »
Different design.  Or cascade more.
Trying to obtain much higher gain from a simple amplifier will also see your bandwidth shrink.  Better to use more stages of less gain.
Seven Transistor Labs, LLC
Offline German_EE
« Reply #2 on: February 27, 2015, 04:44:21 pm »
Rod Elliott knows what he's doing when it comes to audio design and I would be very reluctant to change any of the component values. Also, think of this, a gain of 50dB is about a x316 voltage gain which is a lot for one stage. Best to cascade them.
Warren Buffett
Offline Zero999
  • Hero999
