Electronics => Beginners => Topic started by: Cattmy on September 01, 2013, 07:12:31 pm
Hello all,
I am more a chemist than an electronics guy, so I am wondering how I could add variable current to this Instructable (http://www.instructables.com/id/Variable-Lab-Power-Supply/?ALLSTEPS). It is in essence a power supply made from a Micro ATX power supply that already has variable voltage. I am mainly using this for charging supercapacitors and electrolysis. Any guidance would be much appreciated!
Thanks in advance.
The idea is to sense the current to control using a tiny-ohm valued sense resistor, amplify the voltage produced by the current through the sense resistor and then use this voltage to control a pass element/regulator/transistor/MOSFET.
See the attached, the current sense resistor's amplified output controls the current out of the LM317.
This is exactly what I was looking for. Do you have an Eagle schematic, or a finer drawing, so I can read the component values? Any help would be appreciated. Thanks.
Here's a few simulations that use an INA169 high side current shunt monitor. They work exactly like Paul explains. The control voltage Vset determines the maximum output current. 1A output per 1V input. Vset can be set using a 10-turn pot, for example.
I haven't built either of these so they may not work as-is, if at all.
if you're not too sure about you're doing, a cheap and easy way to add constant current (current limit) is to power your linear regulator from one of these (http://www.ebay.com/itm/DC-Converter-Constant-Current-Voltage-5-35V-to-1-3-30V-LED-Driver-Charger-LM2596-/370709900991?pt=LH_DefaultDomain_0&hash=item5650082ebf) instead of straight from the ATX board. In a linear regulator (LM317) the current going in is equal the current going out, so you get away with limiting the input current.
All the component values are clearly marked. Just download and open these pictures in a picture viewer that has zoom.
I can easily read the values just from clicking on the picture schematics shown here on this page.
If you open the pictures in a new browser window, the whole picture will be automatically scaled to fit.
Ok. Tried that. Thanks.
Another method is to use something like an LM317 or TL431. See their datasheets.
The good news is the circuit is much simpler. The bad news is the transfer function is crap. See attached.
