Author Topic: [TINA-TI or LTspice] Trouble with LM5002 simulation  (Read 412 times)
Offline bodzio_stawskiTopic starter
  • Country: lt
« on: January 23, 2024, 10:49:18 am »
Hello,
I wanted to recreate the LM5002 circuit in the TINA-TI program which seemed to me to fit the Texas chip like a glove.
Unfortunately, the effects of this program quickly took their toll on me, and the circuit simply does not work properly, when it comes to output voltage.
In fact, I could say that the output voltage is close to the set input voltage instead of being increased. A factor that may be crucial in this case is that I had to import the LM5002 chip into the TINA-TI program, which I did using the Tools-New Macro Wizard function.
I downloaded this model of LM5002 from this manufacturer's link:
Link to the LM5002 model
https://www.ti.com/product/LM5002?utm_source=google&utm_medium=cpc&utm_campaign=app-null-null-GPN_EN-cpc-pf-google-wwe&utm_content=LM5002&ds_k=LM5002&DCM=yes&gad_source=1&gclid=CjwKCAiAkp6tBhB5EiwANTCx1I02KymlWGVlOnDBXDaCyRaUBd2jIqiBK5bZqMnmFRwDUyP8UJMsixoCs_0QAvD_BwE&gclsrc=aw.ds
Is it possible that I am making some mistake in running the circuit here?
Link to my file: LM5002.TSC
https://easyupload.io/5u7xaw
« Last Edit: January 25, 2024, 07:33:25 am by bodzio_stawski »
  • Country: lt
Re: [TINA-TI] Trouble with LM5002 simulation
« Reply #1 on: January 25, 2024, 07:32:21 am »
Alternatively, do any of you have an LM5002 model that can run on LTSpice?
I tried to use the same one (in .lib format) from the TI website, but it does not work the same as in TINA TI. When I prepared an alternative circuit with LT1371 in a similar configuration as boost converter, it worked (although it is, of course, an Analog IC, saved with the .sub extension).
