Yeah, I'm thinking in selling it.
I'm a Electrical Engineering student and have been a electronics hobbyist since I remember. I don't have very much experience in production, but I'm intending to start learning this by my self since my college sucks in the pratical side of engeneering, which is kind of a paradox, since It is, well, Engeneering... Well, but this is a problem in most of the colleges here in Brasil...
Getting back to the topic: Yeah, INMETRO is the regulatory body and I think they have similar standards to most of the countries arround the world.
OK, selling your design should be doable - lots of companies and individuals do it all the time. I have no idea about the applicable product liabilities in Brazil so this is just based on how things are roughly done here. There are 2 things you really need to sort out for yourself:
1) the requirement for formal conformity to code and regulations. That i guess is where INMETRO would/could enter the picture. In Europe we have the CE mark, what you have is for you to find out and then act as you see fit.
2) the actual product safety and compliance in real life. This is largely associated with sound design principles and best practices, not so much rules and regulations, although the 2 have a strong correlation. To cover this point, you need to find out the relevant design rules, recommendations and practices that directly apply to safety and Electromagnetic Compliance (EMC). Things that come to mind here are:
- As a mains supplied device, your design automatically comes into the scope of such standards as IEEE 587 and IEC 60664;1-5. Now you get rules: these standards have strict requirements for things such as overvoltage management, impulse voltage and current tolerance, minimum flashover and creepage distances in circuit boards and other structures in high energy circuits. And lots more. Your mains input automatically by its nature becomes a circuit classified at least as IEEE 587 Cat A / IEC 60664 Cat II. It would be good for you to understand what that means.
- For EMC the device needs attention to EMI filtering and power factor correction. The latter in this particular case is hardly needed but wherever there are switching power supplies, interference is possible. It would be good if you at least understand the intent and aim of such documents as EU Directive 2004/108/EC, CENELEC EN 61000-6-1, -6-3 and VDE 0871. In your case the power levels may be low enough not to worry, but at least understanding that this legislation exists is your advantage.
In my country the local electrical code and legislation states something like this (not verbatim) "It is permitted for individuals to maintain such plugged electrical devices they have constructed for themselves for their own use...". The code specifically allows maintenance, by extension it must allow construction, because if not, there can be nothing to maintain. I have not the slightest idea if this applies for you or if it is relevant to your product. However, offering the product as a kit that plugs into the mains would fulfill the wording of that code. And limit your liability at the same time, since it would be the buyer who builds the device. In case of accidents, it would probably/possibly be enough if you can demonstrate that the design fullfills the stipulations of the standards as far as safety is concerned.
I don't mean to scare you but really, do think carefully about safety when thinking about selling products connecting to the mains. Lots of the chinese onehunglow manufacturers do not, and as the old Romans used to say - vestigia terrent.
