Hi all!
This is my first post, so go easy
I ordered a pair of second hand nokia Bluetooth headphones last week, with the listing saying they weren’t charging properly, and the battery only lasting half an hour. A bargain at a fiver, I thought. My plan was to crack them open, and get a new battery.
Then they arrived...
and i saw the charger.
Living in the uk, alarm bells started ringing when it came with a two pronged EU charger.
It looked genuine from the printing on the case, but I was still wary.
Then Dave's voice was heard in my head; "Don't turn it on; take it apart".
So, for your delectation, here is what I found ( see attachment ).
It looks like it was intermittently charging because the solder holding down the 400V capacitor is loose.
No fuse. No full rectification. No opto-isolator.
The worst part, however, is the un-snipped leg of the transistor. While it isn't touching the nearby terminal, it is resting just above ( about 0.5mm) the trace... which is directly connected via the diode to the mains live rail. And the leg of the transistor? Ah, it’s only directly connected to mains neutral.
All I can say is thank god I don’t have a euro adapter, and thank god for Dave Jones and his catchphrase!
Hope you all enjoyed!
Caboose
PS: Can anyone recommend anywhere I can buy a uk, electrically sound USB charger? I want to get one, and cannibalise it to charge the headphones. I’ve nicked a genuine nokia charger from someone for now, but I have to give it back.
PPS: While I know my way around electronics in general, can someone explain why the main electrolytic doesn’t explode when the live rail goes into reverse phase? I realise the other leg is on the right side of the diode, so the PD will never be +240 across the legs the wrong way, but doesn't having the wrong polarity on one leg for 50% of the time have a detrimental effect?
PPPS: The board is in the bin, but I've kept the lead
