Author Topic: Gain chip  (Read 716 times)
Offline alamwteTopic starter
  • Country: af
Gain chip
« on: January 21, 2021, 06:45:22 am »
Hello,
I am looking for a tunable laser diode to tune its wavelength in range of 1550nm that I found Gain-chip.
Would you tell me what is Gain-chip and what is its difference with tunable laser diode?
Thanks
Offline mikerj
Re: Gain chip
« Reply #1 on: January 21, 2021, 01:41:36 pm »
A gain chip is simply a semiconductor optical gain device which is required at the heart of any solid state laser.  However a gain chip by itself is not useful as a laser, they are designed to be used in conjunction with an external cavity so you would have to add the grating, mirrors, isolator etc. and get everything aligned, not a job you could do without some fairly specialised equipment.
The following users thanked this post: alamwte
Online Zero999
  • 0999
Re: Gain chip
« Reply #2 on: January 21, 2021, 01:56:16 pm »
Over what range does the laser need to be tuned? I admit I don't know much about lasers. I would think you need to adjust the resonant frequency of the optical cavity, to tune the laser.
Again, as I asked in the other thread, what's the purpose of the project? What are you trying to achieve?
  • Country: af
Re: Gain chip
« Reply #3 on: January 22, 2021, 06:19:18 pm »
 I need a tunable laser diode for my SFP modules. I have a SFP module that uses a laser diode with 1550nm wavelengths
Now I want to have another wavelengths near 1550nm for DWDM device . I want to have a tunable laser diode that I can use for every other SFP module and I just adjust it and have different wavelengths in my SFP modules
When I searched for this tunable laser I found  Gain chip and I didn't know can I use it instead of laser diode.
« Last Edit: January 22, 2021, 06:22:25 pm by alamwte »
