Author Topic: A "Click" with a piezo  (Read 5295 times)
Offline brue
« on: October 15, 2012, 06:04:20 pm »
Hi
Im designing a product that uses capacitive sensor buttons. For better usebility, i would like to have a "click" sound if a button press is detected.
I do not have much space for a loudspeaker, so i want to use a piezo.
But how do i produce a nice sound like a click with a piezo? Is it possible at all?
 I dont want only a crappy biiiip.
Thanks
Offline AndyC_772
Re: A "Click" with a piezo
« Reply #1 on: October 15, 2012, 06:09:50 pm »
I'd have thought that was the easiest sound of all!
Why not test it out? I presume you're using a microcontroller of some kind, so get hold of a sample of a piezo transducer that you can accommodate within your product, and connect it to a spare I/O pin (maybe via a transistor to buffer it).
Experiment with a few different drive waveforms - start with a single logic high pulse 1ms wide, then vary the pulse width and the number of pulses in the burst until you get a sound you like.
Offline ejeffrey
« Reply #2 on: October 15, 2012, 08:42:58 pm »
A step impulse or a single pulse of several ms will usually generate an acceptable click sound, but it may be a bit quiet depending on the size of the piezo element and the environment.  To make it louder you need several pulses, but then it starts to sound more like a beep.
Online mikeselectricstuff
    • Mike's Electric Stuff
« Reply #3 on: October 15, 2012, 10:33:30 pm »
For the best volume, give it a few cycle at its resonant frequency - a very short beep will sound louder than a simple click.
Day Job: Mostly LEDs
