Author Topic: Correct method to trigger on mains AC signal  (Read 237 times)
Offline canvasTopic starter
  • Country: tw
« on: November 14, 2024, 08:52:57 am »
I am about to measure the interrupt time of an off-line UPS on power lost. I will measure its output mains voltage with my oscilloscope. I will be making the measurement through HV differential probe, so the polarity isn't a problem. I am expecting the AC sine wave will gradually deminish to 0V and later, the inverter will switch on. How can I trigger such event on an oscilloscope? Thanks.
« Last Edit: November 14, 2024, 08:55:12 am by canvas »
Offline Andy Chee
Re: Correct method to trigger on mains AC signal
« Reply #1 on: November 14, 2024, 08:56:29 am »
What is your oscilloscope model?
Online ejeffrey
« Reply #2 on: November 14, 2024, 09:25:32 am »
You could trigger on the UPS startup then look at the pre trigger data.  One way would be to measure the current on the battery cable.
