I'm looking for a bench-top power supply to support my electronics hobby (which becomes somewhat professional from time to time). So far I've managed to get by with fixed voltage DC supplies and a bunch of either hand-made or kitset linear regulators, but I could really use a single, stable, reliable constant voltage and constant current source. I tend to do digital electronics, micro-controller stuff, so 3-5A at 0V to 12-18V is probably fine for me. A built-in voltage/current meter (especially the current meter) would be nice, but I don't see that on any of the lower cost units at all. I've read that linear is better than switch-mode but I don't 100% understand why (noise perhaps?). Settable current limiting would be very useful.
Unlike almost all the other similar threads on this topic, my problem is one of
location. I simply don't have access to the full PSU market. I live in an island country (NZ) where everything except scenery is expensive or unavailable. What's more, importing heavy new things like power supplies from overseas is
very expensive. This makes buying such things on eBay impractical, generally. It also means that most brands are not stocked by terrestrial stores, and in most cases they are unwilling to place special one-off orders. The NZ population is small, and demand for this kind of equipment is almost zero. There's very little in the second-hand markets. Most unfortunately, shipping from Australia is more expensive than from the UK or USA. Anyway, this leads me to often go via commercial channels.
One such channel has offered me an
Array 3645A PSU for around NZ$450 (about US$300), discounted from NZ$675. This is a rebadged CircuitSpecialists CIS3645A I believe. It's a linear PSU and I understand the fan isn't overly noisy. A bonus is that it is programmable, which could be useful to me as I do automate things from time to time.
I've also been offered the Rigol DP-832 for NZ$1050 (about US$700), which seems very steep to me, but it's the only place I can get one without having to import it myself (plus taxes & duty & customs hassle). Three independent supplies would be useful sometimes, but I do suspect I'm attracted by the what-ifs rather than what I actually need.
There's a local store called Jaycar (NZ version, similar to the Australian one) that sells generic (usually unbranded) power supplies like
this but I suspect it's massively marked up (from prior experience of Jaycar) and probably just a generic cheap one.
So that brings me to the "TENMA" brand. I can get these through Element14 - and they are significantly cheaper. For example, I could order the
72-2685 for NZ$112 (US$75). It's much lighter on features but at the price of the 3645A I could buy two, or even go for a higher-spec model. However I've read on this forum that TENMA is not a favoured brand so I'm uncertain about these. Can anyone vouch for them?
I want to buy something that will last 20+ years (I look after my stuff) and remain useful indefinitely. So I'm happy to pay for the 3645A if it's a good deal, but I do wonder if there are better options for that kind of budget. For example, the GW INSTEK
GPS-1850D is cheaper (NZ$330), and for a bit more than the 3645A I could get a higher-spec'd GW INSTEK.
I've also considered building my own - I think it's within my capabilities. The problem I have at this point in my life is
time - I have a lot to get done already, and building a PSU isn't going to fit well into my schedule. I'd rather invest in something solid and rely on it for, ideally, the rest of my life.
