Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Electronics
Beginners
Can I trim a NFL?
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: Can I trim a NFL? (Read 1603 times)
LektroiD
Frequent Contributor
Country:
If it didn't explode, I'm happy.
Can I trim a NFL?
on:
August 17, 2015, 04:27:21 am »
I'm using an op amp to drive a mic input, seems in practice the level is too high. I put a trimmer in, and yes it works, but there's a lot of pops and crackles. Would that be down to the trimmer quality, or is there a better way to do this?
Logged
LEK Productions
rs20
Super Contributor
Country:
Re: Can I trim a NFL?
Reply #1 on:
August 17, 2015, 04:50:38 am »
Does turning the pot really adjust the volume? Have you drawn the entire circuit, or left out a resistor from the - input to ground? Because what you've drawn there is a op-amp buffer circuit with a gain of 1, regardless of the feedback resistance (assuming an ideal op amp).
Is it popping and crackling while it's just sitting there, or only when you adjust the volume?
Logged
dom0
Super Contributor
Country:
Reply #2 on:
August 17, 2015, 08:02:45 am »
There's something missing in your schematic.
When using pots as a rheostat [adjustable resistor] it's often advisable to put some fixed R from the wiper to the end to avoid/lessen the problem you are describing.
While adjusting the gain of amplifiers at audio frequencies is usually not very troublesome keep in mind that it changes many properties of the amplifier. Compensation for stability must be done at the lowest settable gain ; phase margin should be plenty as pots are not precision devices and will drift with wear.
Logged
LektroiD
Country:
Reply #3 on:
August 17, 2015, 08:53:47 am »
How's this look? I also included the rest of the circuit...
Logged
LEK Productions
Print
Search
Pages: [
1
Go Up
« previous
next »
Electronics
Beginners
Can I trim a NFL?
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
