Hi, i'm new here and a beginner in deeper understanding electronics.
I am cleaning a seventies receiver, a Sony STR-6046A. I noticed that 2 electrolytic caps are starting to bulge.
Because of this is de soldered them and googled them for specs. Nothing found so far. Because I think they are that old, there is no info to be found on the net in
form of data sheets. So I am trying toi understand what is important to look at when one has components that are without specs provided and are to be replaced.
I have this measuring device : MTester.
https://tkkrlab.nl/wiki/MTesterThe 2 caps that I took out are Nichicon caps, blue and one has H7314 ( 35V 330uF ) and the other has H7322 ( 25V 220uF ) on it
They're positioned on the PCB with 2 others that seem ok. (no bulging)
I do not know what the ripple current is and how to know if it is important in this case?
Note; I do not have the correct service manual for this type receiver. The one I have (from the internet) does not have the same layout so therefore I do not know if I can use it in any way.
