Author Topic: Advise needed for lora gateway  (Read 696 times)
Offline sairfan1Topic starter
« on: May 15, 2019, 06:18:18 pm »
I'm not familiar with with LoRa Gateway, to learn I want to setup a small lora environment where i want at least 10 nodes (lora modules with sensors) to connect with gateway to submit data to server, frequency of submitting data is not too high.  (Later i want to connect even more nodes like up to 200)
I found different kind of gate ways on aliexpress like some are in box with Ethernet interface priced around $100 here, but others are like a (2) modules can be used with Raspberry Pi priced around $150
(1)
https://www.aliexpress.com/item/LG02-Dual-Channels-LoRa-IoT-Gateway-indoor-can-choose-433-868-915mhz/32904986476.html?spm=2114.search0104.3.1.4a0043240UoPf1&ws_ab_test=searchweb0_0,searchweb201602_7_10065_10068_10130_10547_319_10059_10884_317_10548_10887_10696_321_322_10084_453_10083_454_10103_10618_10307_537_536,searchweb201603_52,ppcSwitch_0&algo_expid=1e448ed3-09e1-46e2-a340-770397592809-0&algo_pvid=1e448ed3-09e1-46e2-a340-770397592809&transAbTest=ae803_3
(2)
https://www.aliexpress.com/item/32830271395.html?spm=2114.search0104.3.233.27e362a5SBBAis&ws_ab_test=searchweb0_0%2Csearchweb201602_7_10065_10068_10130_10547_319_10059_10884_317_10548_10887_10696_321_322_10084_453_10083_454_10103_10618_10307_537_536%2Csearchweb201603_52%2CppcSwitch_0&algo_expid=828d5331-6ee8-4ff7-9205-61cbd3c6a80e-35&algo_pvid=828d5331-6ee8-4ff7-9205-61cbd3c6a80e&transAbTest=ae803_3
I want to know which way should i go to setup environment to start learning. thanks
