Is this anygood below in the pic for price
tldr... what do you think?
and is there a decent guide for combing two server psu together
just connect ones +ve to the others -ve then you have series connection. google electrical series vs parallel connection.
but one that has protection in mind to not blow up your dc rc charger then just straight combing them
usually pc/server psu have overcurrent or overvoltage protection so not to damage the pc/server. but as usual, warranty void if seal is broken (if you do your own mod, your own risk).
Also noob question does the dc charger draw as much Amp's as it needs obviously voltage fixed. Or does it push full total amp depending how you wire it ?
my imax b6 charger, we can set how many amp we want, if we set to lower amp, the answer is no, if set to max the answer is yes. which one you prefer? i dont have the luxury or the need for a KW balance charger, nor the luxury to test all the surplus psu advertized. do you? tell us then what do you think when you got one.
![Wink ;)](https://www.eevblog.com/forum/Smileys/default/xwink.gif.pagespeed.ic.cldandycH0.png)
And second noob question, Is it complicated to make the amp/voltage adjustable?
yes. for noobs they have to learn, for more experienced, it will take time. you can search in this forum few designs. i believe diy balance charger also available in the net. i think my imax b6 was from open source design and later made by china cloner, i could be wrong. i bought it instead of design it diy just because it is... complicated. and takes time
not really helpful i guess but i guess you have to pick the spoon yourself to know how it feels. hint: you need to be more specific and show some effort, so we can know your specific case. asking which brand is good which is not can lead to a long pages of debate, not everybody can buy all the brands, for me, any brands are good esp when you see tag such as "used by Dell or HP" psu, but then used and cheap items can be anything, even my used Gossen MetraHit X-TRA was DOA, need some effort to get it back to life. ymmv. cheers.
