MrAI,
take this post from you:
https://www.eevblog.com/forum/beginners/what-exactly-is-emitter-degeneration-anyhow/msg5735353/#msg5735353
Which I quote here:
In the attachment, we can see the plots for the three models. Since the single resistor model (green line) was the only one that came into question, I mapped out the region of validity with the light gray horizontal and vertical lines. The best place is within the square formed by all four of the light gray lines.
We can note that outside that range it's not going to be very good, but inside, it's not too bad. It has the benefit of not having to explain what the calculus definition of dv/dt is which may not yet be part of the coursework. It can certainly be called an oversimplification, no doubt there. The question is, did it have any uses. Well, the answer to that has to be that it has very limited use, that's probably why the complaint came in
You admit yourself that the oversimplification is only valid over a very limited range and it's use is very limited. And here I think you have to admit that the size of the rectangle for which the approximation is good enough becomes smaller and smaller with decreasing bias current to the point of unusable well before the diode forward voltage falls below the knee voltage and vice versa. Those are the things you fail to mention. Instead you choose a bias point where the approximation is reasonably valid in a tiny rectangle to prove your point. I think this is misleading and should only be used by people with experience who developed a solid understanding of what is going on to understand where the oversimplification falls apart. Or in other words: how is someone without experience able to tell when the model falls apart? They don't . When people confront you with that you revert to insulting people in here several times by calling them species of substandard intelligence who fail to lean something from what you have to offer. And till today you continue do so.
You then go on to state that your Vf / If oversimplification avoids complicated math and is as such easier to understand while all that is required is calculating ΔVf / ΔIf at a few points. That's not difficult at all and doesn't require any calculus. Neither does the ΔVf / ΔIf simplification fall apart over a very wide range above the diode knee voltage. (You demonstrated this in an other post.)
In the end, to validate their intelligence you get people like KE5FX and SteveThackery - who probably didn't read anything of what has been discussed here - supporting irrelevant visions backed up with some smart sounding quotes posted by MrAI.
But maybe I've spend to much time reading "the art of being right" written by your favorite author.
Hello again,
So, you explain to me that I've insulted some people, by you yourself insulting some people. You actually even mentioned them by name. Does that sound right to you?
You have to be careful how you interpret things said, they are not always to be taken in the negative sense. For example, by saying that intelligence plays a part in understanding a certain concept, it does not mean that people who do not understand it yet are stupid. For one thing, we all have to learn when presented with ideas we never heard of before. That does mean that we are ignorant of that concept to start with, but that does not mean we boil it down to we are stupid as an absolute, never-ending phenomenon. Once we learn that concept we then have that under our belt.
So in most cases we are just acting stupid, not entirely stupid for all time.
Also, by stating something about intelligence it could be an attempt to get people to think about it more carefully, then they might attempt to learn the concept. A typical dialogue: "John-Boy, you are acting so stupid right now!"
Actually, I don't think anyone here is stupid in the absolute sense, but some may be more stubborn than others. I can be stubborn sometimes too, but I've learned that it's best to consider new ideas than to knock them.
This is a topic we should really take to PM's though it's not helping the OP I don't think. The OP wanted something simple and understandable and has little interest in the behavior of people in forums.
