Author Topic: Aeroflex3500A radio integrated tester  (Read 430 times)
Offline BendanTopic starter
  • Country: cn
« on: September 14, 2019, 12:20:00 pm »
2 MHz - 1 GHz operation
AM / FM transceiver test
P25, NXDNTM and DMR digital test options
The spectrum analyzer's noise floor is below -136 dBm
Audio oscilloscope
Antenna/cable test
Weighs less than 8 pounds.
Continuous use of 5 hours of battery life
-20° to + 55°C operating temperature range
Rugged construction (humidity, height, shock and vibration specifications, MIL RF 28800F Class II certification)
Combine the capabilities of a benchtop radio test set with the frequency domain reflectometer function; the Aeroflex 3500A Portable Radio Tester is a lightweight, rugged and versatile portable platform. The unit measures AM and FM radio transceivers on the workbench, vehicle or field.
The Aeroflex 3500A Portable Radiocommunication Tester now includes an RF spectrum analyzer option that allows the user to accurately view the spectrum of the measured signal.
The device provides the user with the opportunity to isolate the radio installation function from the fast drive through the test function. Frequency domain reflectometers help to isolate cable and antenna problems quickly and efficiently.
