Hi Everyone,
I just got a new AFG-2005 function generator today, and I'm not sure if there's a problem with or if I'm doing something wrong.
I put a 48 ohm resistor across the output and measured the signal across the resistor with the scope.
I'm seeing two things: 1) little noise spikes all across the signal, like little hairs, and 2) instability in the frequency, especially at voltages < 1Vpp.
My scope is a Rigol DS2102.
I'm trying to post pictures, but I haven't figured out how to include them yet.
I hope someone can take a look at this and tell me if I need to return it or if it's me.
Edit:
The first picture is a square wave at 200mVpp and 1KHz. Notice all the ghosting or hairs at the tops and bottoms of the signal. Also, The Freq measurement at the bottom left bounces continuously between about 995kHz and 1.020kHz.
The second is a sawtooth at 500mVpp and I think also at 1kHz. The "auto" button of the Rigol could not trigger on a clean signal.
For both of these waveforms, if I bump up the voltage to say 1.5Vpp, it's more stable, but I still see the Freq measurement bounce around a bit. For the sawtooth, I still occasionally see a waveform 180 degrees out of phase. This flashes across the screen very quickly and I have to hit run/stop several times to capture this.
