Let me start by saying I've seen the "how not to blow your oscilloscope up" video as well as the "scopes for dopes video" and while I feel I learned from those videos it wasn't enough to assail my worries.
I still don't feel like I understand well enough to know where to safely probe, wheter to use the ground clip or not on the probe. For instance I have this alarm clock radio, the alarm function isn't working, I think the oscilloscope could help me test the IC and other paths on the scope, but I feel hesitant to try.
The plug is ungrounded, but if I understand correctly it's still earth referenced via the neutral and because my scope is grounded, I should be able to just use the probe (fixed 10x) on the inputs and outputs of the chip to see what's going in and out? The transformer is 230V > ~8.5V, though it has a center tap for ~4.3 volts so it should be safe from high voltages, but I feel very uncertain about everything I do at the moment.
Are there any procedures, or videos or texts pertaining that teach me how to help one determine where it's safe to probe? What to look for, general principles, clues, tips? In addition to the two videos mentioned earlier.
I don't think an isolation transformer for the DUT is the answer to every question. Also I think I used an IT that I would need to put the earth clamp on the probe and provide an earth reference that way. But I am uncertain where it ought to go, don't even have a schematic for this. I looked at the chip layout but didn't see an earth pin, that would've been my goto otherwise.
I know the proper way is to learn about circuits and electrical theory to the point that it just makes sense, but I am not there yet... Got a book about circuits I started on recently... I feel mucking about with real circuits also teaches me things as well as keeping me motivated to read on.
