Author Topic: air pressure sensor  (Read 1658 times)
Offline Swake
air pressure sensor
« on: September 10, 2014, 12:34:51 pm »
Looking for a cheap and easy to implement pneumatic pressure sensor to fit on an large air compressor.
Measurement range of approximately 2 to 10bar (+ - 150psi) and capable of supporting at least 12 to 14 bar (+/- 175 to 210psi) without exploding.
Digital or analog output, it doesn't matter as it will be connected to an arduino or similar.
Anyone tips for a good sensor?
Offline Swake
Re: air pressure sensor
« Reply #1 on: September 11, 2014, 01:56:27 pm »
Really no advice for this?
I hope not being the first on earth doing something like this :-)
Offline Richard Crowley
  • KE7GKP
« Reply #2 on: September 11, 2014, 02:15:11 pm »
Online Kjelt
« Reply #3 on: September 11, 2014, 02:48:29 pm »
Offline jlmoon
  • If you fail the first time, keep trying!
« Reply #4 on: September 11, 2014, 09:29:19 pm »
How about :
http://noel.feld.cvut.cz/hw/motorola/books/sg73/pdf/5_9sensor_msg.pdf
MPX5999D comes to mind, but 150p.s.i. max, span of 4.5V
Recharged Volt-Nut
Offline Swake
« Reply #5 on: September 12, 2014, 08:10:05 am »
YES! Thank you :-)
'Pressure transducer' is the right name. With this information it is much easier to find the right component of course.
An automotive version it will be. As in the link of Richard. Best solution because easy to fit on the existing tubing. I will choose for an 200psi version. Gives some more headroom for over-pressure.
