That stickiness is probably from what's called a conformal coating. That is not the solder resist. It is applied after soldering for protection from corrosion. So far as I know, it can be almost anything, including an acrylic lacquer, which is susceptible to acetone, MEK, and probably other ketones and esters. That is, solvents in lacquer thinner. Acrylic lacquer has the advantage that it can be soldered through without needing to remove it first.
The problem with "denatured alcohol" in the US and probably elsewhere is that it need not be just denatured ethanol.* In fact, it is probably about 50% methanol. The composition varies depending on manufacturer. Check the SDS/MSDS for whatever you buy. Some contain a ketone similar to acetone or MEK (e.g., methyl isobutyl ketone). Methanol and ethanol have different solvent properties.
*Years ago, denatured ethanol ("alcohol") was used as a non-taxed solvent for shellac. Today, you can still get it, but it is labeled shellac thinner and is considerably more expensive than big box store "denatured alcohol for fuel." If you want something that is cheap and mostly ethanol, try E85 at the filling station. That probably varies by location. What I have doesn't smell too bad.
