Author Topic: Fluke 189 series 2  (Read 10821 times)
Offline sabinbpTopic starter
  • Country: ph
Re: Fluke 189 series 2
« Reply #25 on: November 23, 2018, 10:45:39 am »
oh so David was wrong in stating that the 189II was a rebranded 289. It's technically a 287?
there is no difference between the 287 and 289 apart from the accuracy in logging?
does the 287 have LoZ?
Offline gnavigator1007
« Reply #26 on: November 23, 2018, 11:46:15 am »
Did the 189 II  have the same super cap leakage problem as the 289? If you arrange a meet up, I'd definitely ask to open it up.
Offline Mr. Scram
  • Display aficionado
« Reply #27 on: November 23, 2018, 11:58:47 am »
As a buyer that seems sensible, but as a seller I wouldn't have it.
  • Country: ph
« Reply #28 on: November 23, 2018, 12:00:52 pm »
if I can convince the seller to open it up how do I check if the unit has the super cap leakage?
Offline Shock
« Reply #29 on: November 23, 2018, 01:22:24 pm »
If you look at the photo you posted you will notice no LoZ feature. Compare your photo to mine which has a 287 in it.
This document could be a rough guide, remember there could be subtle differences between the short lived 189II and the 287.
http://assets.fluke.com/Catalog2012/1274458T_EN_w_Pg9.pdf?view=FitB
Does the Fluke 189II have the leaking cap?
https://www.eevblog.com/forum/testgear/fluke-189-with-leaking-surface-mount-coin-cell/
« Last Edit: November 23, 2018, 01:24:10 pm by Shock »
The following users thanked this post: gnavigator1007
  • Country: ph
« Reply #30 on: November 23, 2018, 02:22:10 pm »
oh yeah now that you mentioned it. there is no LoZ
Offline srjaynes49
  • 70 is the new 50!
« Reply #31 on: December 23, 2024, 03:23:02 am »
Replying to this 8 year old question with the short answer.
The 189 uses a dedicated and custom LCD display.  The 189-II and 289 utilized a dot-matrix display that is used to supply all typical characters and specialized symbols.
The 189 II is a completely different system from the 189. The 189 II is most similar to the 289 in all regards, except the 289 having the additional temperature sensor.
The 189 has a nearly instant start up where as the 189-II and 289 boot to an entry page and require a function selection to continue.  Selecting the different functions on the 189 is very quick compared to the more complex “choice list” on the 189-II and 289.
You MAY find a nice marketing comparison in the archive documents at Fluke.
Nothing clever to read here...
Offline BeBuLamar
« Reply #32 on: December 23, 2024, 10:56:12 am »
I don't have the 189-II only the 189, 287 and 289. If the 189-II is the same as the 287 then it lacks Lo Z, Lo Ohms and having less memory for logging.
