Author Topic: Alps potentiometer chassis mount  (Read 674 times)
Offline HextejasTopic starter
« on: November 18, 2018, 11:29:40 pm »
do I need to drill a small hole to accommodate the small stud sticking out of the pot ?
thanks
Offline The Soulman
  • The sky is the limit!
Re: Alps potentiometer chassis mount
« Reply #1 on: November 18, 2018, 11:42:12 pm »
Yes, it will prevent rotation of the housing.
You could try to use a stack of anti turn washers but that is a bit of a hack. (not in a positive way)
