Author Topic: Component ID  (Read 1041 times)
Offline PetaVoltTopic starter
    • PetaVolt
Component ID
« on: July 04, 2021, 02:27:19 pm »
Hey guys,
I’m trying to figure out what components these are. There are two of these parts in parallel, the parallel network is in series with the input power just prior to what appears to be the main motor driver IC. All of this taking place in a variable speed pool pump controller. Unfortunately the motor driver IC has no part number or it’s on the underside of the part.
My gut instinct is it’s an inrush limiter of some sort as it’s in series with the power source. I suppose it could even be a fuse.
I sure wish I had a schematic.
Thanks!
Spencer
