Electronics => Beginners => Topic started by: sebastian henao on April 18, 2024, 03:54:24 am
Title: ALTIUM DESIGNER
Post by: sebastian henao on April 18, 2024, 03:54:24 am
In this video you can see what is happening.
https://drive.google.com/file/d/1e82knod6GN3R2SawlPxKnnixfhyZafib/view?usp=sharing
Title: Re: ALTIUM DESIGNER
Post by: tooki on April 18, 2024, 06:59:41 am
Bruh… why is this a poll?
Anyway, Altium hides text once it goes below a particular size. You can set that size in the preferences, if I’m not sorely mistaken.
I highly, highly recommend running Altium on 4K (UHD) displays. Being able to see detail like net names and pin numbers when zoomed out is a huge advantage they enable.
Post by: Psi on April 18, 2024, 07:33:01 am
Yeah, that's normal, if the text gets too small Altium stops showing it.
I've not played with settings to see if you can change this point, but i've never had an issue with the default.
