Author Topic: Am I dense or what?  (Read 6973 times)
Offline zapta
Re: Am I dense or what?
« Reply #25 on: July 04, 2014, 11:03:28 pm »
Is it 'signal' Ground, or 'chassis' Ground ?  ;)
It's a shaky ground. ;-)
Drain the swamp.
Offline IanB
« Reply #26 on: July 04, 2014, 11:10:25 pm »
When I was growing up in the UK the convention for construction projects was always to put the power source explicitly on the circuit diagram with a symbol and a label, e.g. "9 V battery". Not only would this make the power rails clear, it would also give an indication of the expected power source when building it.
I see the use of "voltage rails" and "ground rails" as a convenient shorthand for engineers, but it doesn't always aid reading comprehension.
