Author Topic: Resistor to reduce voltage for motor  (Read 973 times)
Offline steveggzTopic starter
« on: March 19, 2018, 01:33:32 am »
I need to power a small 20mm mini 5v fan. I have a 5v mean well power supply but I want to use a resistor to lower the voltage to 2.80v. I tested the fan at 2.80 volts (with a vaiable power supply) and it was the quietest while giving enough air. Is it possible to just put a resistor before the fan to lower the voltage to 2.80v? Everything online talks about using a resistor for LED's. I don't get it, can you only use a resistor with constant current?
My power source is 5v 6A
My mini fan is rated at 5v .150 but I want it to run at 2.80v (Its draws around 50mA at that voltage according to my variable ps)
Offline basinstreetdesign
Re: Resistor to reduce voltage for motor
« Reply #1 on: March 19, 2018, 02:37:16 am »
No problem and Ohms law will solve it for you.  You can use a series resistor to reduce any voltage source AC or DC.  That statement comes with BUTs, but it is still true.
If it is true that your fan draws 50 mA when driven by 2.8V then the resistor needs to drop 2.2V at 50 mA.  So the resistor value you need is 2.2 / .05 = 44 Ohms and it needs to handle  ( 2.2V )^2 / 44 = 0.11 Watts of power.
The closest standard value available is 43 Ohms and a 1/4 Watt resistor would do fine.  You can get it almost anywhere electronic components are sold.
DK has them for $0.10 for just one but I'm sure that you can get it many, many other places.
https://www.digikey.com/product-detail/en/yageo/CFR-25JB-52-43R/43QBK-ND/2121
« Last Edit: March 19, 2018, 02:40:42 am by basinstreetdesign »
STAND BACK!  I'm going to try SCIENCE!
The following users thanked this post: steveggz
Offline chrisl
« Reply #2 on: March 19, 2018, 02:38:17 am »
you can try using 3 diodes in series or a 43 ohm 1/2 w (or even a 1/4 w) resistor..
Offline fourtytwo42
  • Interested in all things green/ECO NOT political
« Reply #3 on: March 19, 2018, 09:23:15 am »
These fans often require more current to start so the diode solution maybe better than a resistor, trial and error is king :)
