EDIT: perhaps the thread was more suited to the repair section? I don't know....
Hey there,
I own an Amiga A1200 that has recently shown (likely due to a reverse connector insertion I did, but that's beside the scope I guess) a wrong behaviour.
Basically, the floppy disk motor is always spinning, except briefly at reset/cold boot.
I've had a look at how it's supposed to work and I see this signal is generated by a custom IC called AA-Gayle, depending on the state of two input signals.
Upon further inspection it seems one of the aforementioned input signals that dictate the motor status, _MTR, is always at 0 Volts, and is shorted to ground. I have removed the other two chips that are related to _MTR (one is the chip that generates it, the other takes it as input) to check whether this would make any difference, but I can still see the short to ground.
So my questions are:
1. is it reasonable to assume AA-Gayle is actually faulty? My next planned step is to remove this chip (waiting for proper hot air nozzle) and see if the short to ground of that pin disappears
2. I understand _MTR and the other input signal just go through a flip flop, I wonder if I could then put an external flip flop of the proper type and reconstruct the signal, lifting the relevant AA-Gayle pins
Any help would be appreciated.
