Author Topic: Protection for GPS input  (Read 1061 times)
Offline rakeshm55Topic starter
« on: May 11, 2019, 12:31:42 pm »
How to protect Antenna input signals from ESD?
I have connected a low capacitance ESD diode. What is the standard mechanism used to protect GPS module (Sensitive to ESD) from ESD faults.
Offline Yansi
  • STM32, STM8, AVR, 8051
Re: Protection for GPS input
« Reply #1 on: May 11, 2019, 02:25:05 pm »
You have your answer on the schematic.
Other option is to use a diode clamp.
Offline dmills
« Reply #2 on: May 11, 2019, 02:46:06 pm »
A Quarter wave stub to ground should work and can be printed right onto the board.
regards, Dan.
Online radiolistener
  • Country: ua
« Reply #3 on: May 11, 2019, 03:54:33 pm »
Here is typical solution to protect from overvoltage. In your case, you can use 1:1 RF transformer.
« Last Edit: May 11, 2019, 03:56:15 pm by radiolistener »
Offline Yansi
« Reply #4 on: May 11, 2019, 05:39:11 pm »
regards, Dan.
Will ruin impedance matching and will work likely only rather narrowband.
Also please keep in mind that GPS is like what... 1600MHz? The 1/4 wave stub will be unacceptably long for most applications on a PCB.
Offline dmills
« Reply #5 on: May 11, 2019, 07:07:32 pm »
GPS is rather narrow band, CA is only a MHz wide so less then 0.1% fractional bandwidth, and at ~1600MHz a quarter wave shorted stub will be less then 4.5cm long.
I don't see a problem with a stub line, and if you play it right you can also use it as the choke for the DC to power the antenna LNA.
Regards, Dan.
