Author Topic: amplification into motor with resistor  (Read 1167 times)
Offline CapernicusTopic starter
« on: January 24, 2022, 09:14:54 pm »
So here is a transistor made out of a resistor.
It has a weakness that the more amplification you want, the more load you have to put on the motor.    And the resistance of the load has to be in multiples of the resistance of the motor.
Plus it requires you to match the volts of the signal to the voltage reduction of the voltage divider,  so your going to have to get the volts right going into it,  then it works really good after that.
So you hold the capacitor open,  (and it only takes 1 volt to do it because of the division.)  and the motor will turn off,  if you let the capacitor close,  the current will divert through the motor, and the voltage division will be cancelled, to be the full voltage of the battery.
What do you guys think of this?   :o
« Last Edit: January 24, 2022, 09:24:09 pm by Capernicus »
Offline Gyro
Re: amplification into motor with resistor
« Reply #1 on: January 24, 2022, 09:31:16 pm »
Sorry, you're going to have to come up with a much clearer description than that before anyone can understand what you're talking about. You're going to have a job getting gain out of a resistor though!
Best Regards, Chris
The following users thanked this post: Capernicus
« Reply #2 on: January 24, 2022, 09:34:15 pm »
It turns out it ends up more expensive than using a transistor,  because hi-watt resistors can cost half a hundred,  and transistors even more powerful than this  (x50 amp even at huge amounts of watts) only cost $1.
So it defeats the purpose of it, because of the illogical free market.
Offline Ground_Loop
« Reply #3 on: January 25, 2022, 03:16:27 am »
A simpler and proven, but wildly more expensive approach--I assume that's what you're going for--would be to use an amplidyne motor/generator set.
There's no point getting old if you don't have stories.
« Reply #4 on: January 25, 2022, 03:23:29 am »
That looks really cool!!!   But I look in the schematic on wikipedia. (https://en.wikipedia.org/wiki/Amplidyne#/media/File:US2236984-Figure1.png) and its got valves in it -  Cant valves be used to amplify by themselves defeating the purpose of doing it?
But I know that these schematics.  (Especially cause I do it. :) ) Have red herrings in them,  to make people not see the purpose, as well as making them look like they dont work.
« Last Edit: January 25, 2022, 03:26:50 am by Capernicus »
Offline Ground_Loop
« Reply #5 on: January 25, 2022, 03:29:56 am »
Nope, no valves, just a motor and a generator. And bonus: free energy.
« Reply #6 on: January 25, 2022, 03:30:33 am »
Resistors and capacitors do everything,  dont need anything else.  Even for free energy.   hehe
Here it is in h-bridge mode.
You need 2 isolated power sources to run this thing.     But Ive got an rc battery splitter I can add to it.
The strange thing about rc circuits is the polarity can be either way around and it doesnt affect the system.  (but.... the motor will change clockwisality.)
« Last Edit: January 25, 2022, 03:34:03 am by Capernicus »
Offline george.b
  • Country: br
« Reply #7 on: January 25, 2022, 04:39:23 am »
I think it makes no sense.
The following users thanked this post: tooki, Capernicus
« Reply #8 on: January 25, 2022, 04:58:13 am »
Your right, if this is true, then you can make a computer/robot system out of just wire.
And you can embed them into an ordinary copper pcb youd get from PCBWAY, or some mexican manu-a-facture,  but its hard to get hiwatt resistors to work,  but low watt ones would work ok.
Whats a resistor -   just a wire.
Whats a capacitor - just a close disconnection in the wire.
« Last Edit: January 25, 2022, 05:02:56 am by Capernicus »
The following users thanked this post: BILLPOD
Offline Gyro
« Reply #9 on: January 25, 2022, 09:45:57 am »
@OP. I've asked before, but can you please stop linking your images as Facebook links. I, and I'm sure many others, block Facebook on principle and see nothing other than the text (unless we open your post in a 'quote', which frankly isn't worth the effort).
The correct way to show images (drawings in your case) is to attach them to your post!
The video is another of your ridiculously unwatchable messes, at least use a tripod or something and work out what you're going to say. Even the preview shot is motion blurred.
« Last Edit: January 25, 2022, 10:54:08 am by Gyro »
Best Regards, Chris
« Reply #10 on: January 25, 2022, 02:15:26 pm »
u guys block facebook?   why?
what is this principle's solid foundation?
Offline TimFox
« Reply #11 on: January 25, 2022, 02:21:12 pm »
Getting free energy from resistors is a form of perpetual motion.
Good luck patenting it!  Here is a summary of US patent law for such inventions:
https://www.ipwatchdog.com/2011/10/11/the-patent-law-of-perpetual-motion/id=19828/
« Reply #12 on: January 25, 2022, 02:28:02 pm »
Now you know full wellys I'm perfectly serious about achieving any amount of constant megawatt's out of a resistor,  I have plans for a space ship, to leave the planet and all the useless animals behind, only problem I need to get over is the huge G-forces involved and only can travel in straight lines.  When they show the ufo's changing direction instantaniously I have doubts about it being possible (but these units could be unmanned drone type ufo's).  But and but! after you get a constant megawatt out of resistor what else couldn't be true??
« Last Edit: January 25, 2022, 03:23:09 pm by Capernicus »
Offline TimFox
« Reply #13 on: January 25, 2022, 03:56:35 pm »
Have you tried Kickstarter or its competitors to fund these plans?
« Reply #14 on: January 25, 2022, 04:28:13 pm »
Dont need funding.   Funding is just an excuse for peoples nose powder allowances.
What I need to do, is stop arsin around on the internet and just get my work done.
