I've just replaced the output transistors and emitter resistor which was cracked on my Jungson amplifier and now the bias on the repaired channel is around 10mv compared to the 'good channel' which is ~90mv, it does have the same value (560r) resistors in both channels adjustable position.
My question is how would I change fixed resistor R269 to an adjustment trimmer, would I just put the trimmer where the resistor was and connect the wiper to one of the legs?
Many Thanks
Chris
