Hi, I'm designing a simple stereo AMPlifier board based around the TAS5731M chip.
I've started to design the PCB, I've mostly used as a reference the EVM board from TI.
Unfotunatly due to space constaints I had to compact a section of the board.
Doing so I have the following situation:
As you can see the pink color section is an analog ground, that section should be connected to the main GND via a single 0 ohm resistor.
As you can see the copper fill is creating a loop around the IC pin.
The rounded silkscreen parts are caps, and the top most component of the stack is the bypass for the analog supply of that IC.
The vias are not connected to anythig; they was there due to my original plan of having a small AGND plane on the bottom layer.
How can I prevent such type of loops?
The board is
at least a 2 Layer 4 layer due to impedance matching for the 50ohm single endfed I2S signals, Bottom and inner layer are a ground fill and big power poligons.
On bottom layer there are some power traces.
On the same board I also have a 24.576Mhz (MCLK) clock signal track coming from another board, it is the master clock for the MUX IC (PCM9211).
Such track is quite long, it is about 10cm in my board but it is coming from another chip on the other board, that one is quite far.
So I presume that the total length of such track is around 30cm.
AFIK that signal is feeded into different chips. Is there a way to tap it without adding delay and destroying the signal?
Have a nice day,
Nicolas
