The word stability refers to a lack of unwanted oscillations in the amplifier. It isn't clear what you mean by "stability". If it is a precise output vs input voltage relationship, you will not achieve that without some type of feedback (which will need more active devices, or an op-amp). From the datasheet, you can see that Vgs(th) is specified as 0.6v min, 2.0v max, so it can be anywhere in that range. FETs do not have well controlled threshold voltages part to part. You'll also see that Vgs(th) varies -4.5mV/C, so there is a temperature dependency also.
