What meter should I (beginner) choose?
Can't find any review of SANWA CD770 except this
link with photos
Amprobe AM220
Measure: AC/DC Voltage up to 600V, AC/DC Current up to 10A, Resistance, Capacitance, Frequency, Duty Cycle
AC/DC micro Amps for sensors diagnosis
Large Backlight LCD Display
Diode Test
Audible Continuity Test
Data Hold
MAX, MIN and Relative measurements
Auto and Manual Ranging
Auto Power Off (can be disabled)
Tilt stand
CAT III 600V
AC/DC Voltage: 400mV 4.000/40.00/400.0/600 V
AC/DC Current: 400/4000µA 40/400 mA 4/10 A
Resistance: 400.0 Ohms 4.000/40.00/400.0 kOhms 4.000MOhms/40.00 MOhms
Capacitance: 40.00/400.0 nF 4.000/40.00/400.0/4000µF
Frequency: 10.00/ 100.0/1000 Hz 10.00/100.0/1000 kHz 10M Hz
Duty Cycle: 0.1%_99.9%
€49.61SANWA CD770
3-3/4 digits 4000 count
Easy to read large LCD
Thermo plastic elastomer, high resistance against drop shock
Safety cap on current terminal
Data hold, Range hold, Relative function
Continuity check, Diode test
Auto power off function (30min.)
Display : numeral display 4000
Sampling rate : 3 times / sec.
AC frequency bandwidth : 40-400Hz (sine wave)
IEC61010-1 (EN61010-1) 2001-02
CAT.III 600V Max. / CAT.II 1000V
€53,00 +VAT
