Author Topic: analog amplifier questions  (Read 1413 times)
Offline 1uk3Topic starter
  • Country: at
« on: March 14, 2014, 07:16:45 pm »
hi
i'm building a little device to measure LCR, phase shift, non-linearity,... + a simple signal generator
therefore i generate a signal (DDS <=1MHz, 16MHz sample rate), amplify it, and do a 4-wire voltage/current measurement
i'm not very experienced in analogue circuit design, so i'm very thankful for tips.
problem: for the signalgenerator i want to adjust the amplitude digitally, but i have no idea how to do that! :scared:
i doesn't have to be very accurate and i only need 10-20steps
maybe a digital potentiometer instead of R9?
i try to use cheap parts, so please don't recommend very expensive chips!
her is what i have so far(from left to right):
signal from DDS chip(0-620mV) --> filter --> AB-amplifier -->DUT --> shunts --> voltage/current amplifier --> ADCs
SEE ATTACHMENT!
i didn't put much thought into shunt and op-amp resistor values jet. i first want to know the output voltage range
can you give me some hints please?
many thanks
lukas
and sorry for my bad english :)
