Author Topic: 16 channel PC audio switch with volume control  (Read 3089 times)
Online EPAIII
Re: 16 channel PC audio switch with volume control
« Reply #25 on: August 22, 2023, 08:28:51 am »
"... so only one switch can be activated at a time.?
Unless you cheat by pressing two buttons at one time. Or three. Or four. Or ...
Well, you get the idea.
And finding a 16 gang version is not going to be easy. 8, 10, possibly 12, but 16? I don't know.
A purely mechanical approach would be 5x 3pole, 4way rotary switches. ...
Another purely mechanical approach would be to use "push button bank switches" like in this pic:
Pushing in one button pushes out all of the others so only one switch can be activated at a time.
Paul A.  -   SE Texas
And if you look REAL close at an analog signal,
You will find that it has discrete steps.
Offline wasedadoc
« Reply #26 on: August 22, 2023, 11:43:32 am »
For the switching you won't get much simpler than 16 TRS jacks and a flying lead with a TRS plug.  Similar method served the phone companies well for many years before human operators were replaced by Strowger switches.  Wire the jacks without connecting their ground connections together and no possibility of introducing ground loops.
« Last Edit: August 22, 2023, 11:45:27 am by wasedadoc »
Online themadhippy
« Reply #27 on: August 22, 2023, 12:36:58 pm »
Not just telephones,it was also widely used in tv,radio and music production to route  audio and make rerouting simple
Offline ledtester
« Reply #28 on: August 23, 2023, 05:11:39 am »
One could employ a banking idea with a 2-gang and an 8-gang (or even a single and an 8-gang).
Offline darkspr1te
  • Country: zm
« Reply #29 on: August 23, 2023, 06:27:05 am »
I also agree with the TRS jack idea as you can squeeze a lot of 3.5 sockets into a small area and then you just require one mast cable to slot into what ever source you choose,
A alternative is find a broken beringher 16 stereo channel digital mixer on ebay and fix it or rob it of it's audio control stage as the wifi model has 4 boards (power, mcu,wifi,audio) and can be hacked into a lot of things audio related.
darkspr1te
Online EPAIII
« Reply #30 on: August 23, 2023, 07:51:14 am »
In radio and TV land these are called patch panels. I designed a number of stations and yes, I did always include them.
But they were for emergency situations or times where something unusual happened and the normal electronic routing equipment was not designed or installed for that unusual task. Or for maintenance purposes when test signals had to be inserted or readings taken at various points in the system.
For normal day to day operations, audio and video was routed with electronic switching systems, often following parallel paths. However it was common practice to install patch panels at the inputs and outputs of those electronic routing devices. This allowed things to be re-configured when unusual events occurred. These electronic switching systems were installed in a central location, taking up a significant amount of rack space. A video or audio signal only needed to be brought into them at one input in order to be available at any or all of the outputs which went to different locations in the station. Even audio mixers were primarily used when programming was being created or at the location where the on-air feed was being sent to the transmitter. They were not normally used for routing the audio to different points.
Patch panels were a bit of a maintenance problem due to the mechanical contacts. Many stations had a regular maintenance routine where they were "exercised" by inserting and removing patch cords multiple times to break any corrosion that may be forming on the "normal" contacts. Electronic switching equipment is far more reliable.
Music production is another thing and the facilities are often allowed to just grow when the musicians acquire different items of equipment. Audio mixers of course are more important. But the musicians are not engineers and things can grow into great tangles. I have seen recording studios where audio cables are run everywhere and someone simply goes behind the equipment and moves them around when needed. I have seen some real messes. Sooner or later someone decides to hire an engineer, perhaps on a part time basis, and then the facility starts to grow up.
Paul A.  -   SE Texas
