I was wondering if an analog switch such as the TS3A5018
(datasheet) would be suitable for switching the SDIO/SPI interface lines between two SD cards.
In this case data is written to the SD card at about 100 MB/minute.
The datasheet says the bandwidth of the TS3A5018 is 300 MHz into a 50R load. Would that also be indicative of its performance in this application?
This is an idea to off-load data from a camera by electronically switching between two SD cards.
