I have done it using just a NTC thermistor and a power transistor, with the NTC robbing base current from the transistor, and the transistor, using a PNP power device, TIP131 IIRC, with the collector grounded, and soldered to the crystal can. Temperature was around 70C, selected with appropriate base resistor, and the NTC 4k7 bead stuck to the crystal, and the whole lot buried in some foam insulation. Select on test resistor to give around 200mA on power on, off a regulated power rail of 5V, and then measured the rise after an hour, and adjusted resistor to get to around 70C. Yes horrid tempco of transistor, but as it was all at same temperature it worked out well, and gave the crystal, a cheap one in a meter, a lot more stability. 5V rail could easily handle the 200mA of power extra on start up, and low overall thermal mass made it fast to heat up and stabilise.
