Author Topic: repairing washing machine board Samsung Q1235V  (Read 2461 times)
Offline DaxxinTopic starter
« on: May 25, 2019, 05:29:56 am »
Display pop up for some seconds then goes off maybe protection thing the critical component IC DIP8 TNY267P
across pin1 and 8 with unsoldered C38 i get 80ohm is that normal for this IC?
Offline Arjunan M R
  • Country: in
Re: repairing washing machine board Samsung Q1235V
« Reply #1 on: May 25, 2019, 06:09:52 am »
Here is the block diagram of tny267P
Offline Arjunan M R
  • Country: in
Offline Arjunan M R
  • Country: in
« Reply #3 on: May 25, 2019, 06:13:30 am »
Pin 1 and 8 should not be shorted.You have to replace the ic.
Offline Arjunan M R
  • Country: in
« Reply #4 on: May 25, 2019, 06:15:15 am »
here is the pin names
Offline Arjunan M R
  • Country: in
« Reply #5 on: May 25, 2019, 06:16:39 am »
I think the zener might be shorted in the ic it is right across 1 and 8.
Replace the ic
Offline Arjunan M R
  • Country: in
« Reply #6 on: May 25, 2019, 06:17:21 am »
No its not normal look at the block diagram
Offline Arjunan M R
  • Country: in
« Reply #7 on: May 25, 2019, 06:20:55 am »
Or the mosfets?
Offline Arjunan M R
  • Country: in
« Reply #8 on: May 25, 2019, 06:37:37 am »
I think TNY2xx IC are like rifa caps.Some time ago tny277p in the psu of my computer blowed up with a loud sound.I replaced it and the psu was fine.
Offline Arjunan M R
  • Country: in
« Reply #9 on: May 25, 2019, 06:38:39 am »
In the datasheet it says not recommended for new designs
Offline Arjunan M R
  • Country: in
« Reply #10 on: May 25, 2019, 06:41:07 am »
Yeah it has protection.
Offline Arjunan M R
  • Country: in
« Reply #11 on: May 25, 2019, 06:43:30 am »
Bypass pin(pin1) is the connection point for 100nF external bypass capacitor for internal 5.8V supply.It must not be shorted. It's just for that cap.
« Reply #12 on: May 25, 2019, 03:33:04 pm »
C36 is a levelling o pump ?
Offline Arjunan M R
  • Country: in
« Reply #13 on: May 25, 2019, 03:36:26 pm »
If you mean C36 is levelling the ic, yes.
Offline Arjunan M R
  • Country: in
« Reply #14 on: May 25, 2019, 03:38:22 pm »
Didnt understand what you mean by o pump
Offline Arjunan M R
  • Country: in
« Reply #15 on: May 25, 2019, 03:39:53 pm »
You need to replace the ic to fix it.
The following users thanked this post: Daxxin
