Hello
I'm trying to find a female connector similar to the tall ones used in this photo:
the entire page link is :
http://www.nixieclock.org/?p=411I could only find something like this:
http://www.mouser.com/ds/2/418/NG_CD_66504_AP-691769.pdfthe one i found has a crimp-able end, instead of a solder pin.
i could crimp it over a 0.5 - 1mm wire then solder that wire in, or i could just crimp it with no wire and use the crimped end as a solder terminal.
any other hints on what to look for ? the tube's pin is 1mm in diameter and i need at least a height of 11-12mm to clear the tube's end
