Hey,
after messing around for quite some time with some dodgy 9V to 5/3.3V breadboard converter, I thought, I'd get a "real" powersupply, with y'know knobs, plugs and blinking lights.
And having an old ATX PSU lying around I thought I'd try my hand at one of those infamous ATX to bench supply conversions. I had only done ready-to-solder kits and some messing around on breadboards before, but I thought to myself "I litterally just have to pass the rails thorugh to some switches and banana recepticles, how hard could that be."
About 2 months and ~50 hours of work later, I can attest that it can be quite hard (If you don't know what you are doing and have neither the tools nor skills to compensate.)
I had put everything together for a quick test before final assembly and all seemed well. Then I disassembled everything, painted the box, assembled and soldered everything. Now here is where I hit a wall: The thing wouldn't turn on. The standby power would work, but when I "started" the PSU (shorting the ON cable to ground) it would start to get to the desired voltages, but shut down mere moments later. To my laimans eyes it looked like one of the automated safety shutdowns modern PSUs apparently have integrated.
So I checked and rechecked every connection, thinking I surely must have shorted something somewhere. Having no luck with that, I decided to one by one disconnect everything from the PSU, trying to find the faulty section by process of elemination. Only that faulty section never turned up. I now have the bare PSU module with only mains power attached and it still exhibits the same behaviour, wich leads me to suspect that I must have damaged the board somwhere in that process. A visual inspection finds nothing wrong, wich aligns with me never noticing anything out of the ordinary during assembly. I might have dropped some solder or something on some pins though, so idk.
I know remote troubleshooting is inconvenient at best and regularly annoying, so while I'd be happy to try any troubleshooting steps anyone would think of right now, I have basically given up on that PSU module and have already bought another one from ebay for 5 bucks. I'm not very comfortable with messing with that PSU outside from basic probing, with all the big caps holding 300V and stuff, so buying another one seems like a prudent choice. I debated switching to a custom built power supply, but especially with all the panels already drilled, I don't think the monetary investment would be worth that.
I would however like to not blow up another one of those ATX PSU's so, I'd greatly appreciate it, if someone could look over my shematic and tell me if there is something I could/should improve, especially if there is something that might have damaged the PSU. Thanks in advance for any help
I attached a circuit diagram to this post (the png is a bid dodgy if not zoomed in, but .svg's aren't allowed :/)
My (heavily feature creeped) goals were:
- 3 fixed rails directly from the PSU (3.3V, 5V and 12V)
- 1 variable rail with constant current mode
- a 9V rail, since that's a common voltage for powering stuff
- a 12V fan rail for powering fans while soldering
- a earth passthrough for an ESD strap
- all outputs fused (as a crude form of safety current limiting)
- all rails seperatly on/off-switchable and an indicator (LED) for each rail
Some notes:
- The ATX PSU used is a BeQuiet SystemPower 7
- for the variable rail I used a cheap DC to DC variable power supply module from ebay (
https://www.ebay.de/itm/CNC-DC-DC-Buck-Boost-Converter-CC-CV-4A-36W-Adjustable-Regulated-Power-Module/133404944413) (German ebay, I apologize)
- this is the buck converter used:
https://www.ebay.de/itm/3x-LM2596-DC-Step-Down-Spannungswandler-Arduino-Modul-Regler-LM2596S/252785167788
