Was the FET even turning fully off ? I know from just simple DC mosfet circuits I've tried on a breadboard, sometimes they don't turn off for a while, when lowering the gate voltage back down by hand.
In every computer SMPS I've worked on, they have a voltage divider on th gate, usually like 10k to GND, and maybe 10, 20 ohms back to the driver. And usually they put a diode in parallel with the small series resistor, to clamp the max voltage drop to something reasonable.
Are you familar with LTSpice or any other simulator ? I'd try it in there, you may have to guess or calculate the inductance tho if you don;t have a meter. But you could also see the snubber currents easily.
