I am adventuring myself in the design of a 28VDC linear power supply (for the other specs of the power supply I am using as reference MIL-STD-704F).
AC mains (UK) is rectified from a 100VA transformer which gives an unregulated voltage of about 52VDC.
Because 52-28=24V, the continuous output current of the LM338 is limited to only 2A. Therefore I am thinking to shift the unregulated DC output from 0/52VDC to -17/35VDC such that Vout-Vin of the LM338 is less than 10V.
I have drawn a circuit in LTSpice which seems to give 28VDC output voltage, but when I add a load of 10 Ohm, the output voltage drops to 300mV. Why is this happening?
I am more than happy to do a complete change of the initial design
EDIT: confused Peak-to-Peak with Peak voltage. Removed transformer secondary voltage
