You didn't answer my question:
Is before running PulseView and after the exact same Device instance path?
- I believe so (I'm relying on the Driver File Details tab in Device Manager), but I have some concern about it as it says it's in the windows\system32 directory and I am using the 64 bit version of of PulseView, in case that matters.
Does Windows go "bong" (USB disconnect) when you run PulseView?
- Yes
Did you try using Zadig again?
- Yes
Device Descriptor:
bcdUSB: 0x0200
bDeviceClass: 0xFF
bDeviceSubClass: 0xFF
bDeviceProtocol: 0xFF
bMaxPacketSize0: 0x40 (64)
idVendor: 0x04B4 (Cypress Semiconductor)
idProduct: 0x8613
bcdDevice: 0xA001
iManufacturer: 0x00
iProduct: 0x00
iSerialNumber: 0x00
bNumConfigurations: 0x01I'm getting an error message in Sigrok PulseView that says PulseView failed to open device. Generic /unspecified error.
QuoteI'm getting an error message in Sigrok PulseView that says PulseView failed to open device. Generic /unspecified error.
If you open the settings menu, you'll find an entry named "Logging". Setting the log level to 5, closing it, trying to connect to your device and then going back to the log will give more of a clue. Feel free to paste the text here and I'll have a look. My guess would be that you're missing the firmware files needed to program the LA hardware: https://sigrok.org/wiki/Saleae_Logic16#Firmware
sr: resource: Failed to open resource 'saleae-logic16-fx2.fw' (use loglevel 5/spew for details).
sr: log: libsigrok loglevel set to 5.
Ok, looks like at the end of the day it appears there is no real/full opensource software for making PulseView play with the 16 channel LA that I have (apparently it would require Saleae firmware to work with PulseView software).
So, next up to bat is a new "high voltage tolerant" LA. One that looks pretty nice is the DSLogic Plus and it has some pretty good looking software that comes with the LA - apparently the software is a descendant of PulseView. But as good as the DSLogic software appears, I'd really like to stick with PulseView (although having the option to use DreamSource's software is not bad).
I'd like to avoid a misfire on another LA. Any chance anyone can confirm that Sikgrok PulseView - without any software, firmware, etc. from DreamSource - will really work with the DSLogic analyzer? (Or is this just a path toward Round 2 of the same basic issue - that I got myself into - that started this thread?)
Sure, but you already bought it, right? So once you have the firmware you're good to go. If I was in your place, this is what I'd do.So, next up to bat is a new "high voltage tolerant" LA. One that looks pretty nice is the DSLogic Plus and it has some pretty good looking software that comes with the LA - apparently the software is a descendant of PulseView. But as good as the DSLogic software appears, I'd really like to stick with PulseView (although having the option to use DreamSource's software is not bad).
I have my own personal opinion about DSLogic as the people behind it do not play nice in the open source world because they lie, take what they can get and try to prevent others from taking from them. From a moral point of view, I would never recommend them. From a practical point of view, it's a decent LA and affordable for many, so I understand why people would buy them. They should be aware that the sigrok projects benefits from this in no way, though.I'd like to avoid a misfire on another LA. Any chance anyone can confirm that Sikgrok PulseView - without any software, firmware, etc. from DreamSource - will really work with the DSLogic analyzer? (Or is this just a path toward Round 2 of the same basic issue - that I got myself into - that started this thread?)
The stance of the sigrok project is that we do not actively work on any part related to the DSLogic on our own time because we're not willing to kiss the hand that keeps slapping us across the face. However, we also don't reject efforts by the community, which is why sigrok has DSLogic support for certain models. So if you buy one, you may be able to use it with sigrok. However, their firmware is not open source if that matters to you, and you will not receive much support from the sigrok devs, if any - meaning that if you buy a U2 model, you're out of luck: https://sigrok.org/bugzilla/show_bug.cgi?id=1516
Finding a high-speed true open source LA is tricky at this point and I'm not aware of any commercial efforts. With that, I'm afraid you'll have to settle.
C:\>pulseview.exe -D
