But more importantly, why would you want a safety sign that emits light only in a narrow direction? Surely you want a safety sign to be easily seen from all angles
That's because there are different requirements. Signs can only be viewed in 1 direction, warning lights should be seen 360*, however practically this may not be feasible (IRL). Directional Long distance Warning Lights are desirable and Government rules apply. There are minimum distances and also max brightness rules.
Hm. So what, exactly, is the half-angle from which your signs must be visible and need not be visible?
From what I can see, it appears the claims are that the geometry of a LEP device allows a less diverging beam than with LEDs. I don't understand why that is necessarily the case
That is the property of Lasers, they are Mono-Frequency and in Phase and it's a desirable characteristic. Led's, even narrow beam/band are not the same.
So what?
You ask about "excited phosphor" devices where blue light (from a laser) excites a phosphor. The
photons emitted from the laser are not visible; only the photons emitted from the phosphor are visible.
Now, what is the "mono-frequency" and "in phase" of the photons emitted from the phosphor?
How do you make the phosphor emit the photons in only a narrow beam? Hint: you can't.
If "mono-frequency" and "in phase" photons really are desirable, then your best choice is to use the laser without a phosphor.
Thanks for the Questions
That's a response I would expect from a troll.
BTW: the "Quote" button is there for a purpose.
