While I am learning about the needed op amp, maybe you good folks could give consideration to my options for the power transistor... My options are to use what I have, or buy something else. I would rather use what I have, of course.
Here's what I have in stock:
MJ4502G Power P-Transistor - 100V/30A/200W - Qty(1)
IRF9540NPBF P-MFET - 100V/23A/140W - Qty(2). Curiously, the data sheet description says this component is typically used for 50 watt applications?
SPP18P06PH P-MFET - 60V/18.7A/81.1W - Qty(2).
Data Sheets below.
It appears that two of the available P-MFETs would be needed to manage the watts with sufficient room to spare. It is (I think) within my skills to design the extra circuitry, if using two MFETs is our consensus... Other than there seems to be some debate as to whether the small balancing resistors go in the Drain, or the Source, of the MFETs.
To be honest, it is clear to me that it would require a full college course to learn all the ins and outs surrounding the choice of the op amp. Kleinstein has been kind enough to rule out the ADAD8675 and to suggest the TL071H or OPA991, if having to purchase it. But, I wonder if any of the other op amps that I listed as having on hand might do?
