Here is a summation of where we are in the project, the updated schematic and the questions resulting therefrom.
Summation
- The design goals have been adjusted down to 30V/3A, due to power management considerations.
- A transformer with separate secondaries for the 33V and -5V rails will be used to lessen the total voltage spread. I am not sure that I know what changes this requires in the circuit. I think all it requires is tying the two grounds of the two secondaries.
- The Tant cap was changed to a 10uF e-cap; low ESR and a 100nF ceramic cap was added.
- The op amp considerations seem to be pointing toward the LM101/201/301 series of op amps. The LM201AH has been used as a place holder in the schematic. I terminated the two Balance pins and the Compensation pin, pending instructions.
- I have incorporated two MOSFETs for the BJT and added dual Schottky diodes, for balancing, because that is what I have on hand.
- I added fuses on the supply inputs.
- David Hess’s current limiting design changes are pending his instructions.
- imo’s voltage pot and trimmer design changes are pending his instructions.
What follows… I went back through the posts and tried to pick up any issues that might still need consideration...
@ Kleinstein
“As shown, at the max setting the voltage across the shunt would be 1.2 V and thus relatively high, but to limit the heat there it may be advisable to change to Pot more to 50 K or less, so that the max would be more like 0.6 V or maybe even 0.3 V. The current limit is not high precision anyway. So from the precision the TL071 should be good enough, unless one uses a very low (< 100mV) drop on the shunt.”
Are you saying that I need to change the value of the Current Limiting pot? If so, to what value. Remember, the op amp choice is now narrowing to the LM201AH/LM301.
@ parieanuo
“not sure if D3 will ever work properly, but i haven't put the pen on paper to check if he can light correctly with current draw from adj pin, maybe it's safer to put that missing resistor
anyway i don't like that configuration with led entering conduction linear-like, i like the on/off approach, either the current protection (limit) is ON and LED is ON, either it's off. with your schematic i'm not sure it works that way”
Did you want to suggest a solution? A comparator, possibly?
@ Kleinstein
“If powered from a transformer, and this with some variations and hum on the main supply, it would be a good idea to have a seprate limit for the OPs supply. This could be a simple resistor +33 (or 35) V zener + emitter follower type circuit. So the OP would not see the variations and hum on top the main supply.”
A TL431 Adjustable Zenner has been added to the circuit. I will need help with determining the supporting component values; please and thank you. Should one of the resistors in the divider that sets the Zenner voltage be a trimmer pot?
@ Kleinstein
“If the OP is powered from an extra supply, it does not need to work all the way to it's upper supply at the input.
The OPs listed are pretty similar low noise BJTs and they work up to some 2-3 V to the positive rail only. With the positive supply at some 33 V they would work. They may have a lower limit to the supply and thus powering from the output does not work.”
Two question arise for me from your comments:
1) Excepting “Over-The-Top” op amps, I thought that op amps must be powered at least with the full output they are to drive (via the MOSFETs) plus any voltage drops.
2) Are you suggesting a third transformer secondary to power the op amp separately. If so, I think that is doable.
Consideration of the Back Voltage Diode; D2
D2 is for relieving back voltage. In addition to common 1N4007 @ 1000/1A rectifying diodes, I have two additional types of Schottkies, (in addition to the two MBRD10150CT dual Schottkies that I have already assigned to balance the input voltage to the MOSFETs.) They are
- 1N5818-G @ 30V/1A
- 1N5822-T @ 40V/3A
I am considering what to use for D2. I know that back flow voltage spikes can be very high in voltage amplitude. And, IIRC, that the amperage of those spikes is likely to be small. But, we have the 3 amps of the supply that we must prevent slipping by the MOSFETs. So, I need help in allocating the diodes. I guess D2 could be four 1N4007s in parallel. What’s the trick, here?
I would be glad to provide my KiCad files to anyone that would like them to work with. But, I think I will have to use DropBox to get them to you. The files are too big to post on this forum, IIRC. I will be sure to make them freely available, once we finalize the project.
Thanks for all of your great help. We are making fantastic progress!
