The input circuit design actually works, having purchased this kit out of interest; I installed it in my sine signal generator... as a kit it has an input level problem however, providing a fixed level across the input band-width, it performs okay for a basic frequency meter.
I provided a pre-input level attenuator, and diode squaring for my needs... with a 4k7 across my generator square output source = 4 volts PtP, with a series 2k2 in the signal path, and two back to back IN4148 diodes into C4, that I changed value for 1 Mfd non-polarized for the 10 Htz reading resolution; this gave an input level at the diode input junction, of 1.24 volts at 10 Htz, to 494 mV at 1.18 Mhz, the max frequency my generator can produce.
T1 collector levels with the input supplied = 4.8 Volts from 10 Htz to 1.18 Mhz.
