i'm messing with a regen radio circuit now, 40m band. the audio power amp is an LM386, and there is a darlington pair AF stage before that. the volume is ok, but sometimes i wish it can deliver a little more power, especially for the amateur band.
so i'm wondering if i build my own AF chain, what input signal level does it have to be for the LM386 to sound loud and also have some extra power in reserve. then i figure i'd need to build an AF stage to meet that requirement. and in order to do that i'll have to know the output level of the regen stage, which in turn will require me to know the usual signal level received from air.
i have no equipments other than a multimeter. would some nice people give me some ball park numbers for:-
1) what input signal level is needed for LM386 to be loud and with some reserve? (desktop listening, 3" 8ohm speaker.)
2) what's the output level of a regen stage normally?
3) what's normally the signal level received from air, weak but workable stations?
just some rough ball park numbers from experience will do, so that i'd be able to figure out what AF stage gain i'll need. using the 200 gain configuration for LM486 is fine with me, but if i could get away with something lower than that, then so much the better.
thank you guys!
